Combining supply lines to manifolds?
skyking1
skyking1 Member Posts: 143
edited June 2025 in Radiant Heating
I have two manifolds at the West end, a 4 loop and a 7 loop.
I have a total of 11 (3/8) loops. Do I need to make 2x home runs of 1" to the heat pump, or can I run a single 1" and tee it there?
It is about 5.5 GPM, about 38' of run from the heat pump and plumbing.
