H/W Coil replacement
Robert_H
Robert_H Member Posts: 304
I'm replacing the unused H/W coil on a Peerless EC steam that I service, with a blank cover, new gasket and hardware. The original coil cover is disintegrating but the bolts all turn. The I/O manual does not specify a torque spec or specify coating the gasket with anything. so I'm assuming leave the gasket dry and snug the bolts evenly fill and check for leaks. The bolds are stainless so they should be fine.
Any tips based on your experience?
    pecmsg Member Posts: 7,053
    edited June 2025
    one issue with stainless bolts is there is no stretch or give. Tell snap before you notice any movement.
    grade 5 bolts are fine.
    Never seize is your friend on the gasket and bolts.
    After a few weeks tighten the bolts again.
    Robert_HEBEBRATT-EdHVACNUTEdTheHeaterMan
    EBEBRATT-Ed Member Posts: 20,165
    Agree with @pecmsg
  • BDR529
    BDR529 Member Posts: 376
    Wire wheel the boiler, chase the threads to get the junk out.Grab the stud kit and get washers. Don't hulk them in there. Anti-sieze, little high temp silicone.
    Snug them wait 45 min, get lunch, then snug'em smore.
    Robert_H
    EdTheHeaterMan Member Posts: 12,153
    edited June 2025
    After about 300 hours of operation snug them again.
    Then again at one year.
    The bolts won't move much but you just want to see if it does… Those gaskets seem to shrink over time. No one ever checks them so in about 3 years they start to leak and in 5 years they look like they are 30 years old. I think 25 foot pounds are tight enough if you need to do the torque wrench thing.
    pecmsgRobert_H
    edited June 2025
    I was told by sparky my panel, every few months tighten the connections. It’s amazing how loose they can get on the larger loads in 3, 6, 12 months.
    all from expansion, contraction.
    Robert_H
    mattmia2 Member Posts: 16,746
    Are you torquing them to the manufacturer's spec? When I tightened most of my neutrals with a torque wrench it was more than I would have put on them with a screwdriver and I could only do it with a straight blade, that combo robertson/straight could never reliably take the spec with a robertson without camming out. I think they designed the part then tested to figure out what torque was needed for it to stay tight over the life of the panelboard 20 years later. I really need to get that combo robertson/straight bit that Milwaukee makes.
    edited June 2025
    but back on topic. The gasket material is soft and creeps over time, especially when it is new and when it gets hotter. It should be re-torqued after the first and second and maybe 3rd year. If you made a gasket out of epdm it probably would require less attention but that it also a bit pricey.
    Robert_H
    edited June 2025
    Some receptacles and switches now a Philips or a straight blade don't fit really well. I bought a Klein #731-4 and 732-4. They are like a combo Robertson and straight blade. I can't tell the difference between the two.
    But they fit.
    Why the hell am I still buying tools? I am supposed to be getting rid of stuff.
    Robert_Hmattmia2
    We were always told with electrical stuff to tighten them then go back later and tighten again.
