Size Transfer Pump to Flush a Small Hydronic Loop
Peregrine
Peregrine Member Posts: 32
edited May 2025 in THE MAIN WALL
hello All
what size transfer pump to flush and clean a hydronic loop with a 2 gallon fire tube heat exchanger and total length of 280 feet with the largest loop being 100 feet. it is 3/4 inch PEX.
please help and have a great day.
  • Peregrine
    i am flushing the system. not installing a pump.
    please excuse the miscommunication.
    GGross
    EBEBRATT-Ed Member Posts: 20,070
    hard to say without doing a lot of calculation but any of the small transfer pumps will probably work.
    hot_rod Member Posts: 27,301
    a small 1/2 hr transfer even a small sump pump will flow that
    If it is just an ocassional use get a small plastic sump pump pump.
    If you have a scaling concern get a tankless water heater kit, pump, cleaner, hoses, and bucket, around 80 bucks online
    JohnNYGGross
  • Peregrine
    edited May 2025
    1/2 horse power 25 gpm pump would be
    V=((.408/d sqrd)*gpm )= 22 fps .
    diameter of 3/4 pex is .681
    22 feet per second is good?
    please help thank you
  • Big Ed_4
    Big Ed_4 Member Posts: 3,509
    I use a small Pony pump ….
  • Peregrine
    thank you and have a great day
