Size Transfer Pump to Flush a Small Hydronic Loop
hello All
what size transfer pump to flush and clean a hydronic loop with a 2 gallon fire tube heat exchanger and total length of 280 feet with the largest loop being 100 feet. it is 3/4 inch PEX.
please help and have a great day.
hard to say without doing a lot of calculation but any of the small transfer pumps will probably work.
a small 1/2 hr transfer even a small sump pump will flow that
If it is just an ocassional use get a small plastic sump pump pump.
If you have a scaling concern get a tankless water heater kit, pump, cleaner, hoses, and bucket, around 80 bucks onlineBob "hot rod" Rohr
Living the hydronic dream2 -
1/2 horse power 25 gpm pump would be
V=((.408/d sqrd)*gpm )= 22 fps .
diameter of 3/4 pex is .681
22 feet per second is good?
please help thank you
I use a small Pony pump ….
thank you and have a great day
- 123 Chimneys & Flues
