What Am I Working On? An abbreviated photo dump of the month's activities.
Troubleshooting and writing proposals is how I spend most of my time. The toughest part of it is switching gears several times per day between the multiple systems, locations, and clients.
The first picture is a municipal steam-to-water heat exchanger that provides hydronic heating to a church and food pantry in midtown Manhattan. They're overheating.
The second is of a Leonard mixing valve in Brooklyn. Water temperatures are inconsistent.
Third is an Aerco Benchmark getting too hot too quickly.
Fourth is an NTI high efficiency system installed by the irretrievably clueless.
Fifth is a duplex ejector system in a single family residence that needs constant attention because it fills with cooking grease twice a year.
6th is a high efficiency boiler installed with a back-pitched flue resulting in daily lockouts.
Last pic is graduation day for my Plumbing and HVAC students at The General Society of Mechanics and Tradesmen of New York City's trade education program called Mechanics Institute. This is a big day for me at the end of every 2-year program.
Questions and comments are most welcome.
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes
Thank you! I’m glad to hear it.
Classes0 -
You look like the proud dad after the kids graduation from middle school. Great work John both with your students and all your jobsite work. Thanks so much for sharing.
I feel like i have to visit the general society next time i'm in NYC.
You can't imagine. The home is staggering.
Classes1 -
Thank you, @Larry (from OSHA) ! Teaching isn't what I'm best at, but it's the best thing I do. Enjoy the holiday.@.
Classes2 -
This. And when you visit, see if you can get @JohnNY to show you over the steam system.
Consulting3 -
I always enjoy your pics/posts.
That Leonard mixing valve. Inconsistent, fluctuating water temps are a sure sign of the internals gone bad.
I did a multi-building commercial project where we replaced many mixing valves like that with Symmons commercial-grade valves. They had the largest series mixing valve. I'm not sure, but I believe it was something like a 7400 series valve…?
The problems went away and stayed away. If ever there is a need to replace the internal thermostat, they are relatively simple to service with minimal downtime. And consider installing an inline round dial-type thermometer on the mix. It will give you an immediate and consistent read of the temperature going to the fixtures.
Again. Great post. Always enjoy your stuff.
@Intplm. thanks for all that. It’s much appreciated. Yes, we’ve learned the Leonard valve is temperamental and some seem to require a semi-annual rebuilding and o-ring replacement while others just don’t. I haven’t figured out why some are more vulnerable than others, but this one, when it works, performs better than the two 2.5” Holby valves sitting next to it.
It’s a 3-zone DHW system in a 25-story building so the zones all operate at different pressures.
Never a dull moment…Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Classes1 -
That's a great observation. Thank you. I'll look into it. Right now I'm buying rebuild kits 2 at a time,
Classes0 -
try a LegioMix a self cleaning ball valve design
Living the hydronic dream0
- 109 Chimneys & Flues
- 976 Plumbing
- 387 Solar
- 17 Recall Announcements
