BEST BOILER FOR NEW CONSTRUCTION
OldDudesHideout
OldDudesHideout Member Posts: 2
edited January 23 in Gas Heating
New Construction 40 x 64' Building, 40 x 40 is Shop, 36 x 24' is attached Apartment. 5" Concrete Slab with 5/8 Pex installed for radiant hot water [antifreeze] heat. 2x6 walls 12' high 24" centers, 6/12 Pitch Steel Roof, Steel Ceiling. No windows, One 32" Entrance Door w 1/2 light Glass, one 9x8' & one 12x10' Overhead Commercial Insulated Doors. Rockwool Brand Insulation [Mineral Wool], R23 Walls, R60 Ceiling. Inside walls will be drywall.
Pex from floor is connected to 2 Watts Brand Stainless Manifolds, One 5 loop for shop, [five 300ft loops 12" apart], one 3 loop for apartment, [ three 250 loops 12" apart]. Set up for one zone for shop, one zone for apt.
Would like to know Best Boiler & size to use with LP gas. Thanks in advance!
Northern Minnesota 56401
    hot_rod Member Posts: 25,354
    So many good boilers on the market. A mod con would be my choice for a radiant slab application.
    I have used a number of the Lochinvar products, with 0 problems. The Knight series is a great unit, floor or wall mount. Built in Tennessee.
    Ideally you would run a heat load calc to size everything. A wild guess around 60,000 BTU/hr?
    I'd look at the Knight 85,000 BTU/ hr.
    LRCCBJ
  • GroundUp
    GroundUp Member Posts: 2,368
    If you're planning to install it yourself, find something that local suppliers carry and local contractors are familiar with. First Supply in Brainerd carries NTI and IBC if I'm not mistaken. Goodin carries Navien and Lochinvar. I'm about 45 minutes from you there and I install either Lochinvar or Burnham (though my source is out of Rogers). Best in the business is a Lochinvar Knight, in my opinion, though the price is considerably higher than most. The Lochinvar Noble and Burnham Alta are a very nice budget friendly option and what I typically install but I have a number of Knights around Gull and the Crosslake area.
    EdTheHeaterMan Member Posts: 10,777
    If you are looking at a professional installation for your new construction, I would go with the contractor that has the best reputation for Hydronic Heat in your region.  The contractor that does the best work and understands how the stuff operates, will be able to take the boiler that they prefer (even if it is not a premium brand) and have you in great shape, while a less that par contractor will be able to screw up the best boilers on the market.
    The installer is more important than the brand of boiler, In my opinion.
    GroundUpGGrossSuperTechIronman
  • cook_ch
    cook_ch Member Posts: 4
    edited May 26
    Which one did you end up getting? I actually wanted to ask for some advice about boilers recently. I left a request on a website, but instead of helpful responses, I started getting what seemed like scam calls pretending to be from Amazon. It was really frustrating and a bit scary. I found this article about it Has anyone else had this kind of experience? How did you handle it?
