Well pump
creger.robert
creger.robert Member Posts: 109
edited May 2025 in Plumbing
please see picture
What is screw below pressure switch - like a regulator water dripping out
  • leonz
    leonz Member Posts: 1,816
    edited May 2025
    That is a pressure regulator, why is there pressure regulator under the pressure switch???……
    Where is the centrifugal pump suction pipe?
    Please post images of the piping and the front of the centrifugal pump housing.
    Is this 220 volt Flint and Walling centrifugal pump pulling water out of a below ground cistern??
  • JUGHNE
    JUGHNE Member Posts: 11,552
    Is this a 2 pipe jet pump?
    That may be the adjustment for the inducer jet that is down the well.
    Intplm.
  • creger.robert
    thank you I appreciate the information
