Well pump
creger.robert
please see picture
What is screw below pressure switch - like a regulator water dripping out
That is a pressure regulator, why is there pressure regulator under the pressure switch???……
Where is the centrifugal pump suction pipe?
Please post images of the piping and the front of the centrifugal pump housing.
Is this 220 volt Flint and Walling centrifugal pump pulling water out of a below ground cistern??
thank you I appreciate the information
