Grundfos internal checks
hot_rod
hot_rod Member Posts: 27,415
A wise decision, it is easier to install than un-install theses checks. They are not always needed, or desired either.
GGross
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    We have been installing the Viega rebranded Grundfos 15/58…26/99 (Black) which did not have the check installed.. The check needed to be purchased seperately !
    As you said …It's easier to install vs. to uninstall these Check valves.
    BTW …The Viega rebranded circs are less $. 😉
  • Big Ed_4
    Big Ed_4 Member Posts: 3,529
    I can't get them out without breaking them .. I am thinking Grunfo came without the check installed on the side .. I could be wrong ..
    HVACNUT Member Posts: 7,426
    Still better than when the IFC was first introduced by Taco with the check in the volute. Good idea packaged separately but in the box if needed.
    SteveSan
    mattmia2 Member Posts: 16,690
    like it mentions, the alpha always had it separate.
  • GroundUp
    GroundUp Member Posts: 2,513
    The Alpha series, the UP26 series, and the 15-58F all come with the checks separate from what I've seen so I was wondering what they were thinking by installing them in the FC. Hopefully they start putting a rubber band around the covers on them too like they do for the F series. Far too many broken speed selector shafts from loose covers.
    I think pretty much all the PSC type circs will disappear in the next few years. Is 2026 now the timeframe, although it keeps moving.
    This is why you see all the circ manufacturers coming out with more and more ECM versions.
