Clocking a meter...
I have seen a few of these new digital gas meters arrive on the scene here in New Hampshire.
Any thoughts on how to clock these??
I guess we're stuck in the 20th Century here in NY...seen some digital gas meters, but ain't had to clock one yet…It might be easier given the technology.. What does the screen say when static? Flowing? Mad Dog
Might be tough if you don't get a cubic foot readout. Have you asked the utility?
I told nyseg that I wanted an analog mechanical meter reinstalled after the contractor installed a remote digital meter. I told them that I have a pacemaker and I do not want this meter mounted on my home because of the radio wave radiation they generate.
They replaced that meter after they received my letter requesting its removal. They charge $11.00 a month to have it read by a meter reader.
I found this on the web
To get a CFM (Cubic Feet per Minute) reading from an Intelis digital gas meter for a particular time frame to determine accurate appliance usage, you'll need to follow a few steps. The Intelis meter typically provides cumulative gas usage in cubic feet, but you can calculate the flow rate (CFM) over a specific time period. Here’s how you can do it:
Step-by-Step Guide- Locate the Meter:
- Find the Intelis digital gas meter, which is usually installed outside your home or in a utility area.
- Access the Display:
- The meter has an LCD display that shows various information, including gas usage.
- Record the Initial Reading:
- Press the button on the right side of the LCD display to cycle through the different display screens until you find the gas usage reading.
- Note down the initial gas usage reading in cubic feet (CF).
- Start the Appliance:
- Turn on the appliance you want to measure (e.g., furnace, water heater).
- Record the Final Reading:
- After the desired time period (e.g., 1 minute, 5 minutes, 15 minutes), press the button again to cycle through the display screens and note down the final gas usage reading in cubic feet (CF).
- Calculate the Gas Used:
- Subtract the initial reading from the final reading to determine the amount of gas used during the time period.
- [ \text{Gas Used} = \text{Final Reading} - \text{Initial Reading} ]
- Convert to CFM:
- To convert the gas used to CFM, divide the gas used by the time in minutes.
- [ \text{CFM} = \frac{\text{Gas Used (CF)}}{\text{Time (minutes)}} ]
- Initial Reading:
- Initial Reading: 1234.5678 CF
- Turn on the furnace.
- Final Reading:
- After 5 minutes, Final Reading: 1235.7678 CF
- [ \text{Gas Used} = 1235.7678 , \text{CF} - 1234.5678 , \text{CF} = 1.2000 , \text{CF} ]
- Convert to CFM:
- [ \text{CFM} = \frac{1.2000 , \text{CF}}{5 , \text{minutes}} = 0.2400 , \text{CFM} ]
- Consistency: Ensure that no other gas appliances are in use during the measurement to get an accurate reading for the specific appliance.
- Repeat Measurements: For more accurate results, you can take multiple measurements and average them.
- Safety: Always ensure that the appliance is operating safely and that you follow all safety guidelines provided by the manufacturer and your utility company.
If you have any specific questions or need further assistance, feel free to contact your utility company or a qualified professional.
AI-generated answer. Please verify critical facts.
2 - Locate the Meter:
I'm curious how much longer this will be allowed to continue with electric and gas meters.
Yes, the smart meter on your house is an issue for your pacemaker but the cell tower pumping out 20W in multiple directions 24-7 right down the road isn't a concern at all. Not to mention the cellphone in your pocket…..
I constantly see people with multiple wifi routers etc in their house complaining about how dangerous smart meters are. This is ridiculous.
3 -
My tinnitus started after they installed the second cell phone tower close to my home. I leave my cell phone off unless I need to use it.
back to the op. there presumably needs to be the function of a diagnostic dial on the electronic index. it is not just for clocking the input of an appliance, it is also a quick safety check and a few other functions.
what happens if you push the button?
I wonder if this meter can be read with an RTL-SDR dongle and the rtlamr software.
Lots of these smart meters transmit their information completely in the clear. Free software and a cheap digital receiver 'dongle' will let you decode all the meters in the neighborhood.
I don't know about this particular gas meter, but I can vouch that the mentioned hardware and software decoded my electric meter with little effort.
https://github.com/bemasher/rtlamr/blob/master/README.md
You can probably read it with a Flipper Zero.
- 15.8K Strictly Steam
