New furnace installed, does this look right?
Had a new 96% gas furnace installed in my 30x30 single level home with 11 heat registers.. The heating company connected all 11 heat runs to a 16x20x5' plenum, I have 6 heat runs coming out the top, 4 on the side, and 1 out the back, is this installed right?
I need to see the Static Pressure #’s
Where would you find the static pressure numbers?
Looks like a clean install. All hard pipe with sealed joints and no flex, much better than most.
You have a home run type of setup, if most of those ducts just a couple of elbows and are sized for the correct flow, they work quite well. If the system was designed, there should be some drawing somewhere. If not, at static pressure measurement at the supply and return plenum would be good to confirm that the ducting is sufficient.
There should be some way to balance, typically this is either dampers at the takeoff or dampers at the register boot.
I would like to see the return ductwork but it looks like a decent job from what I can see. Not sloppy like most jobs.
Clean work, even the PVC joints are neat.
Crawl space? Is it wet or humid down there?
It is a nice neat job. The supply duct is a Spider System. Short plenum, and multiple legs. The one off the end cap can cause issues. Everything is air sealed nice. Are those plastic supports considered "Fire Rated"? Is that DWV PVC? The female ends look pretty shallow for sch. 40.
Has it been fired yet? What brand furnace? I don't think I've ever seen one with the gas valve tucked away on the side like that.
A+++ for neatness.
D- for design and execution.
- 15.8K Strictly Steam
