Gas Heat pump or Gas SS liner exhaust?
Which is better, cost efficient, and durable? Why?
Gas, hot water take with pump exhaust or gas hot water take with SS chimney liner exhaust?
    HVACNUT Member Posts: 7,308
    I don't think you're asking about a gas/heat pump water heater, or even a heat pump at all. You're asking for pros and cons between a gas fired atmospheric water heater vented into a chimney vs. a gas fired power vent water heater?
