Direct to load mini buffer
I have a 20 gallon tank on my A2WHP now. With one zone I don't really need much or any buffer.
This Siegenthaler suggestion uses a 5 gallon capacity tank, gives me the direct piping with a Discal on the top supply, still engages some tank on the return. I'll add a magnet in a well on the bottom also.
A modified Harbor Freight air tank with some Caleffi parts welded in. I have a choice of connections tailpieces with the threaded G thread adapters welded in.
Taking it to a professional welder for a leak-proof tank on the first try :) Then blast and powder coating.
will they fix the factory welds that can't be dropped?
It is actually a 14 gauge tank, much thicker than and expansion tank, for example. I've dropped those many times.
Bob, thank for sharing your work. I love this comment, "Taking it to a professional welder for a leak-proof tank on the first try :)
We own two welding machines and I do not possess the skills to get a watertight weld on the first attempt with either machine. Maybe after three or four attempts, I may get lucky, but it will look like a five year old did the welding.
The guy that does our welding for the last thirty years has done about twenty repairs for us on jobs. He has also welded about one thousand joints for us on 1" through 12" steel pipe, and some stainless pipe. As of today he has NEVER had one leak, on his first attempt. Unfortunately my guy is in his late seventies and may retire someday…
Daikin shows 18l is what is needed to defrost their 4 ton unit. So it should work on the small Viessmann I have.
Love the ferrules on that sensor. I just got the tool.
tool? didn't he just solder 2 pieces of 5/16 tubing in to a smashed down male adapter?
oh, the "bootlaces"? i don't know that i'm a fan, the phoenix connector grabs the bare wire better and it is less likely to break if the wire can flex at the connector, the bootlace sticking out can get snapped off.
1
- 123 Chimneys & Flues
