Mad Dog was amazing
Joe...thank you for putting your faith in me after being jerked around by others. I'm so happy I got the Lion back in the cage. Mad Dog
2 -
Matt just came to my 100+ year old home and completely transformed my original one pipe steam system. I used to have coal so had no vents, and then had a sagging return that was not allowing the back half of the house to heat up. He put some serious vents on (finally doing the coal conversion! only 60 years late haha), then replaced and re-hung the "frowning" return, put in a vaporstat for ultimate low pressure control, and finally put some serious drain valves for the the return lines. The house not only heats up in half the time but radiators that have never worked finally are working and there is no banging etc. Unreal transformation thank you. A true steam expert.
6 -
@Mad Dog_2 is one of the best.
Consulting4 -
Coming from Frank Steamhead Wilsey, one of MY heroes, I'm dang Proud...Mad Dog
Dan...thank you so much for the kind words & compliments. You were a pleasure to work with. Mad Dog
