The leak
photokynetics
Member Posts: 73
In my aqua balance boiler system there are these aluminum type radiators either the homeowner or the installer use these rubber hoses to connect the supply hot water lines, is this normal or was he just lazy?
Everybody knose a rubber hose with a hose clamp needs to be tightened periodically, especially where the temperatures go from extremely hot to extremely cold, this mess was hidden in a wall above a cabinet with no access and there's three more clamps just like it!
What do you plan on replacing those rubber hoses with?
I don't have any idea what I will replace the rubber hoses with. I'm open to suggestions!
