Triangle Tube Challenger DHW not going above 100F
HeatingHelp
Administrator Posts: 715
This discussion was created from comments split from: Triangle Tube Challenger domestic hot water does not maintain temp.
Looking to understand more about these systems. Just bought a place and the DHW is not going above 100 deg. Looking for good starting points. Thanks
Welcome @Mikey318 - I created a new thread so your question about your particular system wouldn't be lost at the bottom of an old thread. It would also be helpful to post pictures of your system to help our community troubleshoot your issue.
Forum Moderator
First thing to do would be to confirm the setpoint outlet temp of the unit, and record the temperature at the fixture. Take note of any mixing device on the unit, and anti-scald valves at any fixtures. pictures help
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
