Can this valve be saved
to try to fix it you would have to drain the system so you might as well change it. chances you can fix it are very small
It depends..If it's a Gate Valve and the stem isn't snapped off, and you can get it apart, it's worth one good shot. Mad Dog
2 -
We used to rebuild them in place with graphite packing & Teflon tape & packing. Mad Dog
2 -
My thought exactly. Yes, it can probably be fixed — at least enough so that it will come close to shutoff. If it's been open for a long time, however, it is unlikely that you could get it to shutoff completely. Is it worth the effort? Hmm…
Getting it apart is my main challenge. Am I right to believe there is a bonnet nut/top on the valve (so I need to turn the larger hex area while supporting the valve to stop it from twisting)? Just use two 3 foot wrenchs and see if it will open?
If you really want to save it cut the copper tubing and unscrew the valve from the pipe and put it in a good vise. Put some heat on it and it will come apart.
Too much yanking with big wrenches will ruin it. Then clean it up lube it and repack it.
Or just put in a new valve.
As others have mentioned why do you need it? The ball valve was probably put in because the old valve was leaking by. and it is a Gate Valve.
Yes you can get it apart, the guys above have suggested.
The question is… can you get at the gate sealing surfaces in the body and on the gate well enough to get all the corrosion off and get them flat and sealing again? Umm…
I would use citric acid and not anything more abrasive than rubbing compound if the citric acid didn't get it all off.
- 120 Geothermal
