How to Install a Toilet? Step-by-Step Advice
Need an :eek: smiley. 😬
The ONLY DWV copper I have seen that rotted out is on carbonated Soda waste lines at Pubs & Restaurants...not on Sanitary...Levitt houses in Long Island are all DWV Copper waste. These are Post WW II built homes..so were taking 75-80 years of service. Mad Dog
2 -
If steam mains rott out from holding water why don't radiators?
they rot out more from years of liquid water getting thrown in to the mains from various ignored issues.
If you wait 150 years they will probably rust thru……unless someone pees in them, then probably earlier.
The few steam carrying pipes I have seen leaking had no slope or were level, not draining. After 70-80 years the leaks showed up.
Also rads are cast iron and most steam pipe is black steel pipe, around here anyway.
Then consider wet returns, maybe only 25 years.
How about those lead closet bends? I've replaced a few that had electrolysis generated perforations over the years. Lead and oakumed the new closet bend. Poured the lead when there was access. Lead wool when there wasn't.
Two btu per sq ft for degree difference for a slab2 -
Aside from clearance issues, is there any reason to use a closet bend instead of a no hub quarter bend? Less chance of stuff getting caught in the sharp angle.
Interesting.
I'm still on the fence on ripping the little bit I have out. Others had lead me to believe it was best to get rid of it.
This is where experience comes in really really handy.
I could never understand closet bends. Code says to use sweeps when you go from vertical to horizontal.
They were probably made that way for upper floor toilets where you had to stay inside a joist bay.
The only place that this is allowed by code is a toilet. It's The reason was that the toilet would break down the solids when introduced to the drain. It is also the only place to allow for a reduction in dimension on the run, ie. 4 x 3 inch ninety… four inch in three inch out.
We used to install vent ells with a street flange when replacing some closet bends it tight spaces. Worked, works fine.
Code also used to allow for three quarter bends serving a toilets discharge. I never had to do that and wouldn't do it now due to all of the low consumption toilets in use today. Twelve eight and three gallon flush types were fine with it back when.
2
- 15.8K Strictly Steam
