viega tubing-black
need to find fittings for this tubing
1" id
1-3/8 od
1-3/16 inside
1-1/8" outside
looks like 1" and 1-1/4"
but may be metric
where can i get fittings
PEX? I think that uses standard stuff. Viega Pure Flow® PEX fittings and adaptors are available at Supplyhouse.com
Any pex tube with the ASTM 876 or 877 can use any fitting that has the ASTM F 1807 listing. Regardless of brands.
Viega has a nice pex fitting, but you will need a specific Viega crimp tool.
With the copper crimp rings, any tool brand will work.
Fittings are available at any plumbing wholesaler, big box stores, online.
1" Sharkbite and other grip type fittings are also approved for pex. If you have a simple repair needing only 1 or 2 fittings. No special tool required.
They do. Oetiker might as well.
Viega PEX does use standard crimp size fittings, but your recorded measurements don't match the dimensions of SAE PEX tubing. Viega does not make a metric size, as far as I know.
1-1/4" pex is 1-3/8" (1.375") od
1" pex would be 1-1/8" od
Most pex in the US is CTS, copper tube size, same OD as plumbing copper type L,M or K.
I didn't know Viega made 1-1/4"?
I have used this Watts brand 1-1/4" pex with the copper crimp rings, although it may be discontinued. Fittings and crimp may still be available.
