viega tubing-black
need to find fittings for this tubing
1" id
1-3/8 od
1-3/16 inside
1-1/8" outside
looks like 1" and 1-1/4"
but may be metric
where can i get fittings
    EdTheHeaterMan Posts: 12,940
    edited March 2025
    PEX? I think that uses standard stuff. Viega Pure Flow® PEX fittings and adaptors are available at Supplyhouse.com
    hot_rod Posts: 28,699
    Any pex tube with the ASTM 876 or 877 can use any fitting that has the ASTM F 1807 listing. Regardless of brands.
    Viega has a nice pex fitting, but you will need a specific Viega crimp tool.
    With the copper crimp rings, any tool brand will work.
    Screenshot 2025-03-18 at 8.24.45 AM.png Screenshot 2025-03-18 at 8.22.36 AM.png Screenshot 2025-03-18 at 8.24.11 AM.png
    Fittings are available at any plumbing wholesaler, big box stores, online.
    1" Sharkbite and other grip type fittings are also approved for pex. If you have a simple repair needing only 1 or 2 fittings. No special tool required.
  • GroundUp
    GroundUp Posts: 2,573
    Viega PEX does use standard crimp size fittings, but your recorded measurements don't match the dimensions of SAE PEX tubing. Viega does not make a metric size, as far as I know.
    edited March 2025
    1-1/4" pex is 1-3/8" (1.375") od
    1" pex would be 1-1/8" od
    Most pex in the US is CTS, copper tube size, same OD as plumbing copper type L,M or K.
    I didn't know Viega made 1-1/4"?
    I have used this Watts brand 1-1/4" pex with the copper crimp rings, although it may be discontinued. Fittings and crimp may still be available.
