Estimated life expectancy?
Anyone care to hazard a guess on the life expectancy of my boiler? It was installed in 1996 so it's nearing 30 years old. The bottom is rusty including flakes that seem to be concentrated at the joints between sections. But those joints aren't leaking (at least not currently). Does a leak ever seal itself up with rust? Another heating season? Or replace now?
Homeowner in Middletown, PA
1936 house with 1996 Burnham V74 oil-fired 1-pipe system
What does the top of the boiler look like?
If it were me, I'd replace it this summer. What would the point be of delaying it? Rolling the dice on having it fail in January?
See my sight glass boiler videos: https://bit.ly/3sZW1el5 -
what brand is it
It's a Burnham V7. @ChrisJ Do you mean top of the sections under the hood?
The tops of the sections looking down the flue passages.
@danmayer175 You can add some boiler seal to the boiler. Boiler seal will buy you some time while gathering the funds to get this done as soon as possible. Get it done in the warm months.Do not wait till the fall.
He says it's not currently leaking so he's got that going for him. And from what I've read of Burnham V7, that thing doesn't owe him anything
That Burnham could start leaking in 10 days or 10 years. The point is, it has served its useful life and is on borrowed time. If funds are available replace it during the summer when the steam pro's are less busy dealing with emergencies.
If you wait, it is a gamble. Naturally boilers fail during the coldest, most inconvenient time of the year. Sometimes you can limp by until spring, other times you can't and it becomes a true emergency.
2 -
Or do some reading, youtube watching etc and buy some tools and do it yourself if you're good with your hands.
I see they have the covers pulled off so I assume they're at least curious about such things.
The heating season is coming towards the end. If you make it to May, take your time and get someone to replace the unit. Yes, do some research as to what you need. You have till September.
nother Burnham bites the dust!!
@AdmiralYoda 10 days-10 years?? Its a Burnham I will give it 9 days.
5 -
I hear a lot of gripes about Burnham. But the factory is in my back yard so I was thinking of using one.
just do your research on the model!
at least this one had a long life!
Vari-valve is in my backyard but I cringe when I see them in someone's house. And they are seemingly in every house around here.
My understanding of steam boilers is that there's a small number of active brands, with some re-badging going on.
There are models with top taps (Burnham, Weil-McLain, Peerless,..) and those with steam take-offs on the side. (Dunkirk, and at least one other brand that escapes me at the moment). They can work but I wouldn't buy one. Seems like a solution in search of a problem.
Then there is the seal between the sections. Burnham and Peerless use steel push nipples. Weil-McLain uses a type of polymer O-ring that is sensitive to pH. Mine lasted > 30 years but I did not buy another one.
Then there is the Burnham hate; their reputation is all over the map; it may depend on the model.
From all this, I think Peerless is the safest bet. Top tappings, push nipples, and I've never heard anyone say anything bad about the brand. But I only started learning about steam a little over a year ago, so take that into account…
cheers -matt
2 -
Are you ok Bob?
Do you feel the same way about the atmospheric gas SteamMax models? Their marketing info also claims a newer design, one where there are no pins above the water line (which makes me wonder why they still offer the IN).
(These are the same models that Peerless recently apparently rebadged and announced as their 63-X series)
I am not sure that the new Peerless is a rebadged Steammax. Some of the specs are different. The right-left dimensions are different and the front-back dimensions are different. The heights seem to be exactly the same. And for what it's worth, I called one of the reps and they did not know anything about the new line. Was the first that they heard of it.
OK re-jacketed SteamMax 😅
Nice job noticing those differences @STEAM DOCTOR . The I&O manual is basically identical. I agree the whole thing is weird even to me who is so ignorant about so much of this industry and its players.
Thanks for calling the rep, I was wondering if anyone had done this.
I think Peerless is using sheet metal in between the sections, to bump up the efficiency. I don't think the steam Max uses those
I think Burnham calls them "Flueway baffles" if we're talking about the same thing. But now I'll try to stop hijacking this thread.
You are right. I stand corrected
I was referring to the 3 pass Steamax, I have not seen enough on the newer pro boilers to have an opinion one way or another.
Please excise my typos, my fingers don't always listen to my alleged brain.
Bob
3PSI gauge1 -
I wish I could burn gas but it's not an option for me. Oil works and my tank is not too old.
Megasteam without a doubt……
Time to start sizing up everything.
What @ChrisJ said. The Burnham MegaSteam is by far the best boiler for oil. Many even buy it just to convert it to NG because it is pretty good design.
I knew he was talking about the MegaSteam, but then I asked if he might also know anything about the newer SteamMax atmospheric which also has some marketing language about being redesigned specifically to do better with rusting out than the IN
He could save on delivery charges!
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 941 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
