Recommend a towel bar radiator
any recommendations on a effective towel bar radiator ? Hoping to provide some heat and warm bath towels .Thanks -Paul
As much as I would prefer to buy local, the selection around here is pretty sparse. Try shopping overseas. I've used something pretty close to this before:
Thank You ! I'm going cross eyed looking at all that's available! none have mentioned BTU or delta T until all your suggestions
For some reason, we don't install many towel warmers and when we do, they are usually Runtal's because I recommend them. I think they're ideal for bathrooms and kitchens and they have many sizes to choose from depending on BTU requirements.
Proper placement is important. A little higher and they could have fit the toilet paper dispenser in. : )
That's a beauty. I wish it was made for one-pipe steam. Not sure what kind of system the OP has.
My solution was to get a big (36") double towel bar and hang it directly above the existing radiator.
BTW, I have two Castrads radiators that I'm very happy with. Their service was great.
We have an electric Runtal. Are you looking for a hot water/steam/electric radiator? The electric ones will use a lot of juice, and our rates are high. If you want to heat the whole bathroom, electric resistance will almost certainly be the most expensive to operate, but probably be cheap to install. I believe Runtal also sells a control box that can be used to set a timer/schedule.
The electric ones are sometimes a better option. The hydronic type don't always work so well as a zone of their own
The electric work during AC season also
I think they start around 150W, run them on setback and temperature control
Ive used them with spring wound 30 minute timers. Crank it on before you get in the shower
Living the hydronic dream1 -
I have installed a couple of Runtals — the larger ones can put put a lot of heat if on a high temp system. The last one I did is in a house with only floor radiant so the water going to it is not very hot — you can still feel that the towels are warmer than the room.
I ordered mine so the supply / return fitting goes straight out the bottom/ back into the wall — so no 90 fitting. For control you really need to have them on a dedicated zone. I did a thermostat and zone valve but you see them also set with a Danfoss head and either a diverter setup or a zone.
I built a cabin and crafted my own but that only works is a non formal setting — one was copper and the other was black pipe .
