New vaporstat
2»
    mattmia2 Member Posts: 16,030
    ideally but it is a product there isn't a lot of demand for so i don't think it quite got redesigned correctly when they stopped making them with mercury switches
  • KJB
    KJB Member Posts: 83
    I still stand by my previous statement. So since I got the boiler back up and running, now I can't build any pressure on the boiler. Been running for about 25 minutes and not 1 oz of pressure
  • KJB
    So it finally built up pressure and cut out right where it is set…about 4 oz. I have the diff set at 2, but the boiler will not restart until all the pressure is off the system and then a little time beyond that before I get a restart. Is there a way to adjust only the diff?
    if the radiation is matched to the boiler it will never build pressure that is the ideal situation. since you were getting steam in the returns, maybe from a cold start there is no steam in the returns yet and some stuff is getting a chance to vent and heat that doesn't on an already warm system.
  • KJB
    I think I'm having venting issues. I can hear it vent sometimes when theres pressure on the system. I've got 2 new gorton #2 vents ready to go on, but didn't want to risk ruining them till I get the blow by of the 2 water seals fixed.
    109A_5 Member Posts: 3,691
    Well I can't say I have been following you whole saga, but if it makes you feel any better my boiler pressure never exceeds:
    2" Water Column
    1.156 Oz
    0.072 PSI
    No pressure limiting controls needed.
    If you truly expect to build pressure (the Boiler size exceeds the EDR) you may now have a leak somewhere.
  • neilc
    neilc Member Posts: 3,140
    edited March 2025
    " Is there a way to adjust only the diff? "
    well yeah, dial the left scale(differential) down to 1, (I think) picture?
    and push the cut out up to 5, an oz or 2 doesn't matter
    known to beat dead horses
  • neilc
    just up enough so you're off the floor
  • KJB
    I meant fine tuning. Like the screw in the back for fine tuning the main pressure
    Steam won't bother the Gortons they are made to close with the presents of steam.
  • KJB
    I adjusted the main to 6 oz and the diff to 2 oz, and it still won't restart until the pressure is off the boiler
  • KJB
    So it would take approx 22 minutes to go from a hot start, to cutout, to cut in and then to cut out again. Does that sound like the right amount of time?
  • KJB
    Even with 2 water seals leaking through? But I guess there is one on the main steam lineal, and that's around 160°
    You may need a more stable setup to calibrate and and verify adjustment and functionality of the vaporstat, like in the video.
  • neilc
    but it restarts, correct?
    what gage scale are you trying to track this on?
    oz's are hard to see
  • KJB
    It initiates a restart approx 30 seconds after the gauge reads 0. The gauge is a 0-3 psi gauge. Only 2 days old
  • KJB
    Just set the main to 6 oz and the diff to 1 oz and it still will not initiate a restart until there is no pressure on the boiler and about 30 seconds after that
    edited March 2025
    the return trap on your radiator may be hot from steam getting in to the return somewhere else and flowing back to that radiator
    the steam in the return will close the vent and stop all venting at that point. anything that hasn't vented when that happens won't heat.
    (i didn't read your other thread with 100 comments)
  • KJB
    There are 2 radiators that are the only ones that the water seals are 130° ish. Every other one is ambient temp
    it could be a crossover trap if that system has them or a drip that isn't below the water line too
    In the short term the inserting an orifice plate that mattmia2 mentioned may be the quickest way the get those radiators under control by limiting the amount of steam entering them.
    You may find this interesting
    https://youtu.be/8KisKrAaywQ
    Mouat water seal movie
  • KJB
    I watched that video. Pretty cool learning about this stuff. Thanks.
    You may want to have a conversation with PMJ, or at least read some of his posts about his Mouat system. I believe he does not use a vaporstat to limit the pressure cycle to cycle. Ultimately you may choose not to use his techniques but you should know the options.
