Permanently Capping/Sealing a Radiator Pipe
Boatster
Boatster Member Posts: 24
I'm removing a radiator that's uselessly inside a kitchen cabinet. The floor is open and I can drain the system, disconnect the supply valve and return elbow, and cap the threaded pipes permanently. What's the best sealant to use if I never need that branch again? A sealant like RectorSeal or Blue Monster? Teflon tape? Something I've never heard of?
  • delcrossv
    delcrossv Member Posts: 2,200
    edited March 2025
    Teflon tape,slic tite or other pipe dope is fine.
    Boatster
  • Intplm.
    Intplm. Member Posts: 2,988
    edited March 2025
    The brand names you mention above are what you want to use. They're fine.
    Boatster
  • Boatster
    Thanks, @delcrossv and @Intplm. Much obliged.
