Stadler radiant heat loop always circulating
2»
    hot_rod Member Posts: 27,444
    Insulation and air sealing is the gift that keeps on giving
    You may find you local utilities offer free or inexpensive energy audits. Might find the info here as well a incentives $$ to upgrade the home or mechanicals.
    Plug in the zip code.
    https://www.dsireusa.org/
    mattmia2 Member Posts: 16,727
    A buffer tank is the right way to do it. some combination of a slab thermostat and a room thermostat, the slab t-stat calls the boiler, the room t-stat shuts it down if it is overheating the room is the odeal way to control it.
    usually the radiant is the base load and the radiators make up if the floor can't keep up or someone opens an outside door or something. a ci boiler without a buffer tank isn't the most efficient way to supply this when there is only a small amount of radiant.
