Short cycling
Realcraftsman
Member Posts: 1
in Plumbing
I just installed a Reeme G 100-200 commercial water heater. It is firing up for just a few minutes then goes off and continues to repeat. How do I resolve this issue?
@Realcraftsman … Do you mean to say you have a Rheem G100-200 commercial water heater?
Is it Natural gas or propane? What are your before and after gas pressures (Inches of water column).?
Do you have the proper sized gas lines?
new unit, where is the installing contractor?
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
