Armstrong Air Furnace GUK075D14-3A
tweetymatuz
tweetymatuz Member Posts: 1
I need help lighting the piolet light I do not remember how to do it.
    EdTheHeaterMan Member Posts: 12,035
    There is a set of instructions on a plate or sticker of every gas furnace since 1950s on how to light a gas furnace. Even the ones with electronic ignition (no pilot)
    Ironman
    It is difficult to find information on that particular model number from the usual manuals on line websites, but I believe that your furnace has electronic ignition that uses a 24 Volt Hot Surface Ignitor to start the pilot each time the thermostat calls for heat. If that is not happening automatically then you need a professional service tech to look at this.
    First thing to check is to
    1. See if the power is turned on (at the furnace and the circuit breaker box)
    2. Make sure the gas it turned on (at the furnace and the gas meter)
    3. Make sure the thermostat is calling for heat (set higher than the room temperature)
    After that, it is time for the professionals to take over.
    Ironman
