Armstrong Air Furnace GUK075D14-3A
tweetymatuz
Member Posts: 1
in Gas Heating
I need help lighting the piolet light I do not remember how to do it.
It is difficult to find information on that particular model number from the usual manuals on line websites, but I believe that your furnace has electronic ignition that uses a 24 Volt Hot Surface Ignitor to start the pilot each time the thermostat calls for heat. If that is not happening automatically then you need a professional service tech to look at this.
First thing to check is to
- See if the power is turned on (at the furnace and the circuit breaker box)
- Make sure the gas it turned on (at the furnace and the gas meter)
- Make sure the thermostat is calling for heat (set higher than the room temperature)
After that, it is time for the professionals to take over.
1
