steam radiator removal and installation DC area?
I have a 1930s steam radiator that I like to have removed, capped and reinstalled after I have it dipped. I've called multiple plumbers and HVAC places and can't seem to find a person or company that can do this.
Can anyone on here help?
  • random12345
    random12345 Member Posts: 504
    edited February 2025
    What do you mean by dipped? Removing the radiator requires unscrewing the union connecting it to the supply valve. Once you do, just close the valve, no need for capping.
  • delcrossv
    delcrossv Member Posts: 2,203
    I think "dipped" here means stripped and repainted.
    Steamhead Member Posts: 18,468
    Consulting
    Ironmandelcrossv
    EdTheHeaterMan Member Posts: 12,131
    Great if only one pipe, but what if there is a return pipe? Or what if the valve does not close completely? And what if they want to get the valve all new lookin' again. The valve needs to be removed for the refinisher. I might have a cap on hand just incase.
    @chesapeake: Sometimes you need to ask the question differently. "What would it cost to replace a radiator?" Then when the plumber gets there, ask him to remove the radiator so you can refinish the floor while he gets you a price for the replacement radiator. (that you will never purchase). You will happy to pay for that service while he is there, and he can walk away with a profit before he even gets the estimate to you.
    When the radiator is refinished, you can see if the same plumber wants to comeback to put it back for you. If not, then call another plumber and ask "What would it cost to replace a radiator?" When he gets there, you can ask him to put the radiator back and he can make a profit without even offering you a quote.
    The way you ask the question often will generate the response you need. Too much detail will reveal that there is not enough profit in just unbolting a radiator. You need to offer just enough to get the home visit to happen. Once there, the work part is easy. And they can charge you for services rendered.
    You may need a moving company to actually get the radiator to the refinisher. they are equipped to move heavy things like refrigerators, furniture, and radiators.
    Just some random thoughts form an old man.
    delcrossv
