ProFlo Press Fittings & Ridgid Press Tool
My company is looking to transition away from brazing water lines and jump into the press world. Any feedback how ProFlo fittings compare to other brand options? We've found ProFlo to be the most cost-effective option, but would like to make sure we're not sacrificing product quality as a result.
Also looking for feedback on Ridgid's RP251 tool. Most of our jobs will be small scale, residential jobs. Both water & ACR applications.
    pecmsg Member Posts: 7,043
    only Viega Fittings
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,833
    edited February 2025
    We have some RP240s. The best money we ever spent.
    Haven't filled the gas in the torch since we bought the ProPress.
    I have nightmares about trying to get the water out of copper at 8pm to solder…. Hours of time wasted. Now it's in and out in ten minutes.
    PC7060
  • offdutytech
    offdutytech Member Posts: 248
    Viega Press fittings or nothing! I've used Nibco in a pinch, but there is a noticeable difference in the quality. The only issue i've ever had wasn't the Viega fitting, it was imported 1 1/4 copper on an emergency boiler change out. Since then it's only been domestic copper and Viega fittings. Just prep you ends correctly and mark your depth once you insert the pipe. You get the hang of it quickly.
    Owner of Grunaire Climate Solutions. Check us out under the locate a contractor section. Located in Detroit area.
    Long Beach EdILikeEmOlder
    mattmia2 Member Posts: 16,681
    it somehow took me decades to figure out that a shop vac is your friend here
  • Long Beach Ed
    How come I never thought of that? Maybe in a few more decades I would have?
    Thank you mattmia2 !!
  • Intplm.
    Intplm. Member Posts: 3,005
    My "B" tank and "MC" tank haven't moved since I started using ProPress.
    All of the Ridgid press tools are great. Viega fittings I have found to be superior.
    What sold me completely was when I prepped a four inch copper water main that couldn't be shut off completely. With water flowing through the pipe, I pressed a four inch valve on in as little as thirty minutes.
    With a torch, that job would have taken half a day if not an entire day. Not to mention the inconvenience that was avoided for the occupants of the building not having to be shut down all of that time.
    @nbeauregard You will like the propress tool and fittings for both ACR and plumbing.
    Long Beach Ed
    EBEBRATT-Ed Member Posts: 20,145
    @offdutytech
    Had the same issue with 2" copper imported from England.
  • offdutytech
    I'd say the only real thing to look at is what size pipe do you typically press. Went with the Milwaukee M-12 great for copper up to 1 1/4 and gas pipe up to 1". This is 95% of the size I work with and the tool was much lighter. The drawback is without the Milwaukee M18 I can't do IPS pipes over 1". For the 5% I just rent the larger Press Tool for a day. We used it to make repairs on a 3" steam main and it was a life saver. Traditional methods of cutting and threading would have made the job take double the time. I like the concept of the ACR press stuff, just not sure If i want to invest in that with all the other AL2 stuff I need to get
    Long Beach Ed
  • PC7060
    PC7060 Member Posts: 1,794
    Nice the M12 can do 1”; the Ridgid 240 is limited to 3/4 mega press. But otherwise great tool. I’ve had very good success with both Viega and JW fitting. With MegaPress; Viega is only option.
    Jaws don’t last forever; if you start to get leaky crimps; replace the jaw.
    if you get a hydraulic flare tool, is there really any advantage of press over flare for acr?
  • Graham_2024
    Graham_2024 Member Posts: 5
    a few years ago, the Viega trainer told me that they can’t find a way for press to work with the high pressure of ACR.
  • offdutytech
    @mattmia2 I think the press ACR has its place in some VRF systems and maybe jobs where hot work permits would be a pain. On a standard resi install for AC prob not unless a company is using newer guys that don't have brazing skills and want to boost production. The flip side is they will never get good at brazing if they don't do it. The NAVAC battery flare tool is awesome. I was skeptical until I tried it. It's almost fool proof and it's made near perfect flares. Use it on mini splits and fuel oil lines. The tool paid for its self on a mini split job while making flares standing on a 8 ft ladder. It was so much easier than my trusty Imperial Eastman kit.
  • offdutytech
    The only other thing to consider on Milwaukee vs Ridgid would be the batteries. I have Milwaukee tools so it was a no brainer having the one charger and batteries than work in multiple tools. Between the tools and pack outs I have done my part for the Milwaukee stockholders lol
    ILikeEmOlderIntplm.
  • GroundUp
    GroundUp Member Posts: 2,513
    I'd agree with the above feedback, but also have to ask…. Why in the world were you ever brazing water lines?
    mattmia2offdutytech
    there is also this type of flaring tool that is similar but hydraulic instead of battery powered. it seems to be mostly popular for automotive applications:
  • Intplm.
    Not any more. One of my associates has been using press for quite a few years now with no regrets.
    zoom lock and RLS have been making refrigeration press fittings for over 10 years.
    Home | RLS Rapid Locking System
    Intplm.
  • PC7060
    I see they offer RLS jaws for several ProPress systems including Ridgid and Milwaukee.
    pecmsgIntplm.
