Safgard 1150 LWCO question
My brother in law called me for no heat on his oil fired boiler. There was no power to the burner and I traced it back to the LWCO, a Safgard 1150. The yellow low water light was on but the boiler showed about 10lbs of pressure with the temperature below 70F, so I think he's got enough water over the boiler.
I jumped out the cutout and the boiler fired. I ran it a few minutes while I looked up the manual for the Safgard and the yellow light on the Safgard went out, so I removed the jumper.
I didn't remove the sensor because I didn't have any tools on me save for my meter, but my question is whether the sensors in the cutoffs go bad or if they need any kind of periodic cleaning. I left him with heat and the LWCO in place but I know if it tripped once it's either bad or there's low water (no leaks found).
Ideas? Thanks.
Thanks Jamie. This house is on a well system, so it's not automatically grounded through the water pipes - any chance this is a weak ground connection?
You need to use thread sealant of some kind.
They don't recommend PTFE tape because it could cause issues but dope will just get cleaned off the threads by normal tightening.
I don't think the building ground matters at all as far as LWCO operation?
Right, @ChrisJ , It's the solid connection to the boiler that counts.
Now for @MaxMercy — I do hope, if the boiler isn't solidly grounded through the water pipes, that it is bonded instead? And that there is a good building ground?
I don't know Jamie, I was only there for about 30 minutes getting his burner running - I didn't investigate any of the electrical except for the LWCO.
What I can tell you is that the house is from about 1960, but it had two additions done to it over the years - the last about 20 years ago when a family room and bedroom suite were added to the first floor when my in-laws got older. The electrical panel seems up to date, and the town the house is in is generally a stickler for permits and inspections, although of course that means nothing.
Update:
After about two weeks of running, the LWCO tripped again (amber LED on), so yesterday I went over to remove and clean the sensor of the LWCO. I looked over the valve arrangement to isolate as much water loss as I could before removing the sensor and noticed the ball valve that feeds the Watts water feed/regulator was closed. I opened the valve and I heard water running into the system, so it was indeed a low on water and the cutoff was doing its job. I left the inlet valve open and watched the pressure gauge on the boiler and it stayed about 20lbs even as the burner ran. I did notice some dripping from the relief valve which probably explains the loss of water so I'll change that this weekend. Thanks guys.
- 50 Industry Classes
