Taco Switching Relay- Aged Out?
Cyclist77
Cyclist77 Member Posts: 253
As I begin to assemble my materials list I was wondering if our 15 year old Taco Switching Relay should be swapped out for a new one?
Since I will be replacing our coal stoker boiler with a CI boiler am I best served with all new components?
Thanks
  • LRCCBJ
    LRCCBJ Member Posts: 1,043
    They are very durable units if not abused.
    Your call………..it's simply a decision based upon money. You spend your money…………you get brand new.
    HVACNUT Member Posts: 7,401
    Everything new. Pipes cut to ceiling. All new wiring and controls.
    109A_5 Member Posts: 3,847
    If it is a unit that the relays are plugged into sockets, I'd keep the old one.
    hot_rod Member Posts: 27,296
    All electro-mechanical devices have a cycle life. It really depends on how many on/ off cycles it has gone through.
    I think those relays are replaceable, probably not the transformer. Those are the most common failures.
  • Cyclist77
    Since it is coming up on 16 years old and I am going all in for a new boiler and indirect water heater. The $ of a new switching relay is really not a large concern.
    So after I change from a coal stoker boiler and my 2 trips daily to the basement. I wonder what I will do with all my extre time!
  • techforlife
    techforlife Member Posts: 127
    Troubleshooting the new electronics issues???😄
    Long Beach Ed
    Well, I'd keep the old one as a spare. The newer versions have no user serviceable components (like relays in sockets). To me it is not about cost, it is about having heat where and when you need it. Spare relays are easy and they can be swapped around.
    Long Beach Ed
  • Cyclist77
    So are there other brands that have the ability to swap out relays?
    Another option is buy a realy box with one er two extra relays. If you have 4 zones, buy a 6 zone. Then you have a spare relay ready to go.
    I don't know that I ever replaced one of the "ice cube" relays in a relay box. Transformers yes, but no relays.
    Consider the Caleffi brand. Easy to replace transformers, auto reset fuses. So far it works with 4 or 5 versions of the Nest, as well as Ecobee and other challenging thermostats.
    techforlife
  • Joe Mattiello
    Joe Mattiello Member Posts: 750
    if it's a 15-year-old relay, equipped with ice cube relays, the relays are replaceable. the current solid-state relays are not. If it's not broken why replace it. you can always replace it if necessary.
    Joe Mattiello
    Taco Comfort Solutions
    Long Beach Ed109A_5
