Have you had refrigerant line-sets develop pin-hole leaks?
Gary Elovitz
Gary Elovitz Member Posts: 15
There seem to be a lot of line-sets (especially with white insulation) that have developed pinhole leaks within 1-3 years of installation. One theory is that the leaks are the result of corrosion due to moisture and air getting in between the insulation and the copper tubing. Line-set manufacturers all include in their instructions that the ends of the insulation need to be sealed to prevent water from getting under the insulation. When I am in the field and see line-sets with white insulation, I see a lot that are not sealed. If you have installed line-sets with white insulation, please choose one of the four options below so we can see if there is any real correlation between sealing the insulation and corrosion of line-sets. Thanks!
Have you had refrigerant line-sets develop pin-hole leaks? 1 vote
I ALWAYS seal the insulation ends and I have had line-set leaks.
0% 0 votes
I ALWAYS seal the insulation ends and I have NOT had line-set leaks.
0% 0 votes
I never seal the insulation ends and I have had line-set leaks.
100% 1 vote
I never seal the insulation ends and I have NOT had line-set leaks.
0% 0 votes
    mattmia2 Member Posts: 16,742
    I have 4 dehumidifiers that have developed leaks in the copper tubing so I think it is the quality of the tubing, it has nothing to do with moisture.
    pecmsg Member Posts: 7,053
    edited February 2025
    the issue with white insulation was resolved years ago.
    It was a chemical reaction between moisture and the insulation material. The ends should have been sealed!
    If you still have that crap, rip it out and replace it.
