Circulator replacement
Good afternoon,
I'm working on a instruct swap out and cannot locate another 005-f2 Circulator pump. Would a 007 e or a regular 007 work? Thanks in advance.
Another question I have that's related to the job, this is a old steam system that was converted to hydronic, I am trying not to drain the system fully do so this job because I fear it will be a nightmare to purge all the air. Has anyone had an issue purging air from systems like this? Any tips?
I am hoping a jet swet may fit into the 3/4 nipple attached to the flange and I may be able to swap out the old flange and close it with a valved flange with out draining the system. I can isolate the supply but not the return.
Indirect swap out *
Your uploaded files are not able to open. Are these files stored on your computer? You need to use a different method to put them on the site so we can see them.
The problem with having a valve on one side of a loop and not the other side makes it impossible to open the system without draining the water above the point where you want to do the work.
As you can see from this Performance chart, the 005 has a similar curve as the 007. it falls just below the 007 performance curve, that said the 007 would be able to do the job that the discontinued 005 pump can do.
Thank you for the reply. I'm uploading it from my phone and I'm not sure why it's not working.
I'm trying to avoid draining the system, have you ever used a tool similar to a jet swet to plug the hole to avoid draining the system?
the pictures seem to be working now.
Yes ye, it was either gravity or steam prior to the conversion.
I may just drain it and do my best to purge the air out.
Might be better to drain it and add isolation valves and a magnetic dirt separator or wet rotor circulators aren't likely to last that long on that system.
Thanks for all the comments. I did not know that was a valve. I have only seen the newer style circ flanges with isolation valves. I am going to soak them before I try and open them.
I will recommend the dirt separator as well, Thanks!
The job went smooth. Thank you for all the help. The existing flange worked and held. You guys are great.
Feel free to tear it apart 😄.
- 50 Industry Classes
