2 problems on a 1 pipe system
Problem 1: At the beginning of a cycle, a few minutes after boiler fires, I hear a rapid-fire banging in the pipes just above the boiler and the boiler turns off. This repeats two more times before the system fully pressurizes for a normal cycle. My thought is that the vent at the end of the closest main is not working (I haven’t heard it in a while and it seems to be stained from dirty water), and maybe this is causing the problem.
Problem 2: After a full cycle, as the system depressurizes, we get very loud banging in the riser/two radiators on one branch. Again my thought is a trapped air problem as I’ve been dealing with bad valves and stuck air-rid vents throughout the house.
Any advice is appreciated, or suggestions for a specialist in deep southern New Jersey!
