Basics of Indoor Air Quality
HeatingHelp
HeatingHelp Administrator Posts: 722
edited February 2025 in THE MAIN WALL
We of the Hydronic Realm often don't think too much about Indoor Air Quality, but that mindset is obsolete. We need to look at the Big Picture, not just the heating system.
Read the full story here
  • BradHotNCold
    BradHotNCold Member Posts: 82
    Recently moved into a condo (built about 1970’s) with HVAC system. During recent routine housecleaning, we vacuumed the cold air return cover. Vacuum pulled lot of dust, dirt, etc. So I said let me pull the cover off and give it a more thorough cleaning.
    To my surprise, I discovered the ductwork was insulated on the inside with about a 1/2” of what resembled fiberglass, but it was more like black rock wool glued to a cloth (?) layer against the wall of the ductwork. Could this be asbestos? If not, is this a usual practice to insulate the interior of HVAC ducts?
    Thanks for any suggestions/advice!
  • BradHotNCold
    Any comments? I searched and my post showed up as “Closed” with comments but I cannot find the comments?
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,087
    Hi, I searched "interior duct insulation" and found both black and grey sheet insulation used for this purpose. It seems to be fiberglass.
    Yours, Larry
    BradHotNCold
  • BradHotNCold
    https://forum.heatinghelp.com/profile/Larry%20Weingarten
    Thanks, but it seems friable so that can’t be good! Guess we will call HVAC SERVICE!
  • Larry Weingarten
    Hi @BradHotNCold , Here's a short description of this type of insulation. Installed right, there should be very little fiberglass available to the air-stream. 😊. https://rezcor.com/product/95198/Johns-Manville-Duct-Board-1x48x120-R-4-Fiberglass
    Yours, Larry
    BradHotNCold
