Bosch Stainless steel Condensing Boiler
Jalen_Jalen2006
Member Posts: 78
in Gas Heating
Nothing weird about that gas valve. It's a zero governor gas valve and operates in a vacuum like most mod/con boilers. Adjusting it is right in front of your face but you need a combustion analyzer to properly adjust the valve.
Have you performed preventive maintenance on the boiler? That's where I would start if you don't know when its was last pm'd
can you be more specific and circle the items I tried to adjust and connect my manometer. I have not seen this type of gas valve before. You said it’s common.
appreciate it thank you I will do that.
