Fin Tube Baseboard Height
Paul S_3
Paul S_3 Member Posts: 1,291
Is there a manufacture that makes fin tube baseboard 6 1/2" high or less? (3/4" pipe)
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
    hot_rod Member Posts: 26,600
    Even the compact versions of fin tube run 8-9" tall.
    You might look at panel baseboard like the Runtal. Lower output, but also lower profile. Much more rugged also
    EdTheHeaterMan Member Posts: 11,574
    edited February 3
    Shortest one I found is around 6.5" high (tall) https://www.sterlingbaseboard.com/documents/DLB-3.pdf
    The BTU/LF. is under 400° @ 1 GPM @ 170° average water temperature. Need more feet of baseboard to do the same job as the 8" and 9" tall models.
    mattmia2 Member Posts: 15,616
    What are you trying to do? You are going to need clearance above and below for air to circulate if you want it to work.
    EBEBRATT-Ed Member Posts: 19,598
    Sterling Petite is/was the shortest I know of. Maybe that is the same one that @EdTheHeaterMan posted.
    Maybe there are electrical outlets in the way.
    Runtal uf2 is 6" high though pricey and standard are 1/2" tappings. Might be possible to order them custom with 3/4" tappings.
