Flex Joint?
Has anyone used a flex joint to isolate boiler vibration from the mains and returns? Something like this:
Homeowner in Middletown, PA
1936 house with 1996 Burnham V74 oil-fired 1-pipe system
Mad Dog_2
    Jamie Hall Member Posts: 27,316
    Vibration from the boiler? Eh? The boiler is vibrating?
    Last I looked, the boiler is usually pretty hefty. It's also usually pretty solidly set, if not actually anchored, to a pretty solid pad of some kind.
    I can't think of a situation where a boiler should or would vibrate…
    So? What is the problem you are trying to address?
    Long Beach Ed
  • Intplm.
    Intplm. Member Posts: 3,003
    I have used them with large circulators mounted adjacent to boilers. They certainly do the job and are also good for when pumps are slightly miss-alighned to the piping.
    mattmia2GGross
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,833
    edited January 2025
    If it only vibrates when the thing spins, you're looking at the washing machine.
    old_diy_guyCLamb
    Aye,,,, I've used them too — but for the pump vibration, not a boiler vibration.
    mattmia2Intplm.
  • delcrossv
    delcrossv Member Posts: 2,203
    The whole "boiler vibrating" thing gives me the willies. 😲
    mattmia2 Member Posts: 16,658
    Maybe some industrial boiler with a power burner. Otherwise the vibration is coming from the circulator.
  • danmayer175
    danmayer175 Member Posts: 60
    Not vibration but noise resonating through the pipes. Most noise seems to come from the motor in the oil burner.
    If it seems to be coming from the oil burner, you may very well be right — but it may not be the boiler transmitting the noise. It is not at all uncommon for the oil supply pipe to be the villain, if it is strapped tightly to either a pipe or to a bit of house structure. Even one place where someone got enthusiastic and strapped it down can do it. Try loosening anywhere that the oil line or lines are in contact with things and slipping something like a piece of rubber around the oil line and whatever ties it down.
