Adding purge valves
ken3320
ken3320 Member Posts: 10
Hello, I have a hot water boiler with 5 zones . There are no purge valves . It does have auto air vents on the high points of the piping . I would like to add some purge valves . I’m sending along a picture. Does anyone have any recommendations as to where to place them ? Thanks
    HVACNUT Member Posts: 7,424
    Can you post more pics from farther back, and from different angles. You should only need to add one. What's with all the switching relays?
    ken3320
  • ken3320
    I added a few more pictures. 1 relay is for indirect water heater , remaining 3 are master br, family rm, and living room which have radiant floor heat. All 4 relays have their own circulators .
    hot_rod Member Posts: 27,413
    are the zone valves on the return? If so a purge valve jut above this large ball valve
    A tee valve like this is an easy install
    bjohnhy
  • ken3320
    Yes they are on the return. I like that idea with the T-drain . Would the other end on that return be an option ? Remove the elbow and sweat in a tee with a valve on the end?
    take that vent out, increase it to 1/2, see what you get for flow. Take the fill to 25 psi or so. It may work for one zone at a time
    You could do a flying connection if you dare
  • Martial_7erran
    Martial_7erran Member Posts: 46
    edited January 2025
    As a practical matter, considering the difficulty of adding a T and valve elsewhere,… Adding a purge valve (or two purge valves as described below) in the second photo, in the horizontal pipe exiting the left side of the second image would probably be the eziest place to add a T and purge valve. Or, maybe in the vertical pipe against the wall on the left side of that first image (above the expansion tank).
    It would be best idea to have purge valves, in the first image, between the ball valves shown and the zone valves above them. But not practicable to add them there now.
    But, I have that and still I learned a need to add purge valves elsewhere, at the lowest point in pipe system.
    At the lowest point and furthest point in the radiator system, add a first 3-way "T" outing to a 3/4 garden-hose threaded (and a ball valve) (for system cleanout), then a full-pass ball valve in-line, and add a second 3-way "T" outing to a 3/4 garden-hose threaded (and a ball valve). Because, at the lowest point, if you have a cast iron boiler, your system may accumulate iron oxide sludge, and that is sometimes too dense or heavy to clear out at the boiler end. so, with these two additional drainage options at the lowest point, you can send pressurized water to there in either direction to the lowest point to flush out the sludge. I figured this out when a radiator section froze this winter (under an open basement window used to provide fresh air to the boiler). Because of the sludge blockage, the expanding water burst the radiator copper tube at a weird place (at end of radiator section).
    before Webstone became a household name, I used these Watts valves. That is a 1/4” purge cock and they flowed enough to purge 3/4” loops. I think the vent ell you have is where I would start. You just need to get the big air out, the air purger should finish off the air removal within hours or a day.
  • Intplm.
    Intplm. Member Posts: 3,003
    @ken3320 Do what @hot_rod says above.
    And while you are at it, install a Spirovent or equivalent micro bubble air separator on the system. I do not see one installed in the pictures provided. It should be installed on the feed side with the expansion tank. Otherwise you will continue to have air issues in the system.
  • ken3320
    Thank you all for your suggestions. I’m sending a picture to verify the correct locations of the 2 possible locations . Would this be correct?
    EdTheHeaterMan Member Posts: 12,127
    edited January 2025
    I did not see any mention of what the radiators look like. There are 5 zone valves. Living Rm, Mud Rm, 2nd Fl., Sun Rm., and Master Bed. No other return piping that is visible in the photos. there is one supply pipe that goes past the 3/4" manifold in the direction of the DHW tank. So, my question: are the zone valves for the Living room and Master bed feeding the radiant floor that is mentioned above? A purge of that type of zone would not remove all the air from that part of the system (unless there is only one loop of floor heat).
    A purge valve would also not work on a Monoflo® designed system or a zone that has any type of Tee to the radiators. The only system that a purge valve actually works on are Baseboard radiators that employ copper tube with aluminum fin elements that are configured in a series loop. Taking the time to install a purge valve on anything other than a series loop of baseboard would be an exercise in futility.
    Remove the auto vent and add a valve there to purge. This is a quick, simple work around for now.
    If you want to get in deeper at the end of the season,
    Add an air sep on the supply out of the boiler, a vertical type..
    Move the expansion tank to that air sep as well as the fill valve.
    The circulator above that assembly, a purge valve below the large red handle ball valve you have in place.
    So all the work could be done on the supply riser. Much easier than cutting into or rebuilding the return for just a purge point.
    Now you have a perfect troublefree easy to purge "pumping away" fix. No more air issues.
  • ken3320
    The only drain is the boiler drain . All zones are the same as this one .
    So, 5 radiant zones? Are these under floor transfer plates?
    If they are slab zones a boiler return might be another thing to consider. If that is a cast boiler?
  • ken3320
    look at the drawing, if I drain that whole loop via the boiler drain , close the boiler drain , then fill the loop with the water fill valve, the 2 small caleffi air vents are the only vents to bleed the air while filling. Is that sufficient??? That’s why I was asking about adding a purge valve ? Sorry if I’m confusing everyone.
    You really want an air purger or air separator in the piping that the water passes through constantly.
    The vents you have will release air as youfill, purging gets enough out to flow the system.
    As the boiler heats more (micro bubbles) air is driven out of solution. An air purger in the hot supply at the boiler, catches and eliminates that noisy air.
    Figure 2-13 shows the multiple devices, their best location and the explanation about air, pressure and temperature.
    2-14 shows where auto and manual vents are typically used
    The small 1/8" air vents you have cannot dispel the air quickly, the catch little by little as the float inside drops.
