Clogged steam mains
what makes you believe the main is clogged?
Are you sure it’s not the wet return that’s clogged?
Or a serious lack of main vents?
For Chicagoland, get in touch with @The Steam Whisperer .
Consulting2 -
Same. Unless it's "clogged" with pooling water.
good point didn’t think of that at first
yes I meant return, one pipe steam, doesn’t the main supply turn into a return ? Boiler, controls , vents on returns all clean . It hits 1.5 full pressure in 45 seconds vs 15 minutes, it stops, water drops to bottom gauge. Then water rises where low cut off allows it to fire, for only 45 seconds , then that’s the cycle. It might take water 30 minutes to fill gauge up 12” to very top. I have auto water feed off of boiler floods . Heat in apartments is messed up , apartment furthest from boiler is 82 today , I keep 72. What else could it be . Mark_ransley@yahoo.com if in Chicago and you are family with this . Is it the boiler? I don’t think so , I heard actual water sloshing in pipe last week,
You have a clogged wet return and/or a pitch problem.
Call @The Steam Whisperer .
Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
