Vent brands and adjustable options?
bipbap
bipbap Member Posts: 233
So I have what I think are a bunch of leaky old air vents causing my water loss.
I've been usually replacing with Gortons but they get pricey and I still end up questioning whether I got the right size.
I know Maid O Mist aren’t highly recommended but I like that they come with adjustable openings and so I have the option to try out different sizes without having to buy a whole new vent.
Is there a recommended brand of adjustable vents like Maid o Mist that people use?
And either way, where are people finding best prices on these?
Just trying to shop around since I may need 8 or so.
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    The Maid-o-Mist vents aren't adjustable in the conventional sense, but they have removeable vent orifices, so you can change the venting rate. You can get a vent that comes with a set of orifices. https://www.amazon.com/Maid-Mist-ANGLE-STEAM-VENT/dp/B016PFFCX8/ref=sr_1_4
  • bipbap
    Oh yes that’s what I meant when I said adjustable- those ones that come with multiple size orifices.
    Are these worth trying out in my situation?
    I feel like I read not great stuff about Maid O Mist so wasn’t sure if there was another recommended brand with multiple size orifices.
  • Hap_Hazzard
    I don't think anyone else uses that approach, but I've been using them for years and swear by them. The advantage to this approach is that, once you figure out what orifice size to use with each radiator, you can get a new vent and keep the same orifice, which is a life-saver when you can't find a new vent in the correct size. Also, if you decide you don't like the Maid-O-Mists, you can replace them with Gortons of the same sizes once you've got your system balanced.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,412
    edited January 2025
    I pay up for Hoffmans , They work….
  • bipbap
    Do Hoffmann come with interchangeable orifices ?
  • Neild5
    Neild5 Member Posts: 203
    I use MoM, it is in a 20 unit building with 92 radiators, in the last 5 years I have had to replace 2 vents that I installed, both failed closed.
    delcrossv
  • Big Ed_4
    The 1A angle comes with adjustable cap …
  • bbillcee
    bbillcee Member Posts: 67
    edited January 2025
    im not a pro but i use the vent rite #1 and like them, they dont have interchangeable orifices but you can adjust them
    delcrossv
  • dabrakeman
    dabrakeman Member Posts: 905
    Ventrite 1 is a great adjustable vent. It is on the slower venting side overall (0 - 0.158cfm @ 3oz as opposed to a Hoffman 1a 0.033 - 0.3cfm or Maid-o-Mist caps at 0.06 - 0.783) and an outstanding choice if you often want to really slow down a radiator. I personally don't think most any radiator ever needs more venting than the highest setting on the Ventrite. The adjustment seems more precise than on the Hoffmans. They are pricey but they are made right here in Michigan in Benton Harbor.
    ethicalpauldelcrossv
  • SteamingatMohawk
    SteamingatMohawk Member Posts: 1,090
    Supply House sells a pack of 5 different orifices fro MoM vents.
  • SteamingatMohawk
    Just the orifices without the vent valve itself.
  • offdutytech
    offdutytech Member Posts: 238
    Vent Rite#1 is my top choice for adjustable ones if a customer wants that functionality. Ironically the supply houses in the Detroit area don't stock them, but they are made in state.
    Hoffmans are just ok, I've had a customer that just wanted them all to match so we used those instead of Vent Rite.
    MOM is the budget friendly option when we have a long list of items that need attention, but need to address balancing or a bunch of bad vents. I had a customer order some of these on their own and noticed they only came with one #5 , but if I buy them from my supply house I get a pack with different sizes in the box. If you go with these order a pack of extra orfices so you can balance your system.
    If you want something a bit more fancy for your bedroom or living room Macon Controls makes a nice adjustable control, but they are pricey
    Owner of Grunaire Climate Solutions. Check us out under the locate a contractor section. Located in Detroit area.
