Buderus g124x
Filip1111
Member Posts: 1
I have Buderus g124x, it is conected to wireles tjermostat. What temperature should i set on furnace it self wheen heating is on (left black wheel on furnace, it has 40, 50 , 60, 70, 80 , 90/auto.
what temperature of water should be in heating system when heating is in full power?
Does your boiler have outdoor sensor connected? if yes than AUTO is best. If no then you don't need the Logamatic Control and you can use the L8148 control only.
Does your boiler have the L8148 control?
1
- 50 Industry Classes
