National 209 series gas boiler - pilot light went out.
briansr
briansr Member Posts: 5
edited January 2025 in THE MAIN WALL
hello I own a 4 unit apartment building and this past week the furnace stopped working as the pilot light went out. I called the gas company and the tech told me that the b-valve seems bad or isn’t working correctly. Any help with a boiler this old? I need to try to get 2-3 more years out if it if possible then I’ll replace with a new system. Thanks for your help.
IMG_0845.jpeg IMG_0844.jpeg IMG_0843.jpeg IMG_0842.jpeg IMG_0841.jpeg IMG_0840.jpeg
    mattmia2 Member Posts: 16,673
    edited January 2025
    Did they check the thermocouple? Does it light if you follow the lighting instructions? The valve and regulator could be replaced with a combination valve by a competent tech if needed but it sounds like the basic troubleshooting wasn't done.
    briansr
    EBEBRATT-Ed Member Posts: 20,145
    What is a "b" valve.
    109A_5 Member Posts: 3,959
    Yeah ??? My guess is the regulator is the 'A' valve, so that makes the Gas Valve the 'B' valve. Maybe official Gas company lingo.
    briansr
    It sounds more like the tech didn't know what they were looking at and they were trying to get out of there.
    briansr
    Does the Gas company replace Thermocouples ? As mattmia2 stated, I also would check (replace) that first. They are inexpensive compared to most everything else.
    briansr
  • briansr
    no they don’t sir! But he was a good guy. Thanks for sharing this! I’ll share it with the HVAC tech that is coming Monday. I appreciate your insight
  • briansr
    @109A_5 Thank you sir
  • briansr
    @mattmia2 The tech was trying to help. They only came to check because of a possible gas leak. He works for the gas company so they don’t perform repairs. I have an HVAC company tech coming Monday to try and get it running after the busted pipes are fixed. I’m hoping the damage was contained to the basement area.
    busted pipes and damage?
  • briansr
    @mattmia2 yes not at the furnace. Tia 4 unit was vacant so our guess is the furnace stopped running early last week when we had frigid temps and the basement pipes burst. The heat isn’t working and the pilot light was out.
    EdTheHeaterMan Member Posts: 12,127
    edited January 2025
    who is repairing the broken pipes? When I lived up north there were several different types of plumber. There were plumbers that did water and drain pipes for new construction. Other plumbers did kitchens and bath for existing homes. That might be the type of plumber that you have to fix your broken pipes. The third type of plumber advertised as a plumbing and heating company. They would do all the kitchen and bathroom stuff, but also install and repair boilers.If you get the plumbing and heating guy, to fix your pipes, he should also know how to fix your boiler.
    briansr
