National 209 series gas boiler - pilot light went out.
hello I own a 4 unit apartment building and this past week the furnace stopped working as the pilot light went out. I called the gas company and the tech told me that the b-valve seems bad or isn’t working correctly. Any help with a boiler this old? I need to try to get 2-3 more years out if it if possible then I’ll replace with a new system. Thanks for your help.
It sounds more like the tech didn't know what they were looking at and they were trying to get out of there.
no they don’t sir! But he was a good guy. Thanks for sharing this! I’ll share it with the HVAC tech that is coming Monday. I appreciate your insight
@mattmia2 The tech was trying to help. They only came to check because of a possible gas leak. He works for the gas company so they don’t perform repairs. I have an HVAC company tech coming Monday to try and get it running after the busted pipes are fixed. I’m hoping the damage was contained to the basement area.
busted pipes and damage?
who is repairing the broken pipes? When I lived up north there were several different types of plumber. There were plumbers that did water and drain pipes for new construction. Other plumbers did kitchens and bath for existing homes. That might be the type of plumber that you have to fix your broken pipes. The third type of plumber advertised as a plumbing and heating company. They would do all the kitchen and bathroom stuff, but also install and repair boilers.If you get the plumbing and heating guy, to fix your pipes, he should also know how to fix your boiler.
1
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
