Hoffman vents
Porcellini230
Member Posts: 5
can I replace a Hoffman 40 with a Hoffman 41 if I use an elbow
Yes
41 tongues may warrant a bit more vertical clearance than a typical elbow provides. Close nipple and coupling should do the trick.
- 15.8K Strictly Steam
