Switching Relays- Are they all equal ?
Cyclist77
Cyclist77 Member Posts: 253
So in selecting a switching relay for use with circulator are they all equal? Or do some "perform " better than others?
I currently have a Taco but will be switching my boiler , topossibly a Navien, and I see Navien offers one hand I'm guessing there are a few others out there.
Thoughts?
    hot_rod Member Posts: 27,296
    Caleffi boxes have some unique feature
    RWC thermostat connections
    Snap in transformers with auto reset fuse
    3 sets of dry contacts for heat call
    3 pump relays, two configurable
    Terminals for all the 120v, no wire nuts required
    Pump exercise
    post purge
    Large box with plenty of wiring room
    Easy knock outs
    Front mounted indicator lights
    Piping and wiring guides
    Tech support by technicians
    Made in Canada
    https://www.caleffi.com/sites/default/files/media/external-file/03619_NA.pdf
  • Derheatmeister
    Derheatmeister Member Posts: 1,659
    We perfer the Taco and Tekmar products.
  • Caleffi gives you many wonderful options and landings for every wire. Controls lacking landings are tiresome.
    One wish I have for Caleffi is that they make their knockouts a teeny bit larger. NBD because they are plastic and I just ream them open some.
    A Unibit works to enlarge them, or if you want wires to enter thru the back use a Unibit to make an opening.
    UL doesn't require that cardboard fiber divider between 120V and 24 V because we have the 120V terminal strip. Cleans up the look of the box a bit.
    Thanks for the Caleffi support :)
  • tcassano87
    tcassano87 Member Posts: 129
    what navien are you switching too and how many zones do you have?
    The newer Naviens can handle 3 Zones without the need of an external switching relays wire the thermostats and circulators right to the unit itself
