Switching Relays- Are they all equal ?
So in selecting a switching relay for use with circulator are they all equal? Or do some "perform " better than others?
I currently have a Taco but will be switching my boiler , topossibly a Navien, and I see Navien offers one hand I'm guessing there are a few others out there.
Thoughts?
Caleffi boxes have some unique feature
RWC thermostat connections
Snap in transformers with auto reset fuse
3 sets of dry contacts for heat call
3 pump relays, two configurable
Terminals for all the 120v, no wire nuts required
Pump exercise
post purgeLarge box with plenty of wiring room
Easy knock outs
Front mounted indicator lights
Piping and wiring guides
Tech support by technicians
Made in Canada
We perfer the Taco and Tekmar products.
Caleffi gives you many wonderful options and landings for every wire. Controls lacking landings are tiresome.
One wish I have for Caleffi is that they make their knockouts a teeny bit larger. NBD because they are plastic and I just ream them open some.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
A Unibit works to enlarge them, or if you want wires to enter thru the back use a Unibit to make an opening.
UL doesn't require that cardboard fiber divider between 120V and 24 V because we have the 120V terminal strip. Cleans up the look of the box a bit.
Thanks for the Caleffi support :)
what navien are you switching too and how many zones do you have?
The newer Naviens can handle 3 Zones without the need of an external switching relays wire the thermostats and circulators right to the unit itself
