Quality problems with adjustable vent-rite #1?
hi all- a few years back I replaced a lot of my non adjustable vents with what I thought was high-quality adjustable vent-rite 1#s. I recently had cause to remove some of the radiator covers and while the heat was on, I noticed that a couple of them have what appears to be hairline cracks. Did I just get unlucky or have others experienced this issue as they are not cheap and don’t want to spend upwards of $100 to replace these two if they are just going to fail again. Can they develop these cracks or likely that they were defective when I installed them?
All vents fail. Try Maid O Mist, $15 at supplyhouse
https://www.supplyhouse.com/sh/control/search/~SEARCH_STRING=maid%20o%20mist%20vent
I understand that some may fail in the open position (or closed) but is it common for them to develop cracks?
They all fail in their own way. Cracks happen, there is a lot of expansion and contraction.
Yes, the older imported Vent-rite vents crack. They claim they are now made in USA, so the new ones may be better if yours were imports. We're trying about 50 of the USA ones this year and so far none have cracked or failed.
Our best results over the past 45 years have been with Gorton vents.
- 86.7K THE MAIN WALL
- 55 Biomass
- 102 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 102 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 935 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
- 17 Recall Announcements
