What type (part #) of HONEYWELL zone valve do I have? They are 25 years old.
mpmn04
Member Posts: 3
in Oil Heating
Look like standard V8043 zone valves.
The valve has a inverted flair pipe connection . Normally you would fine them on baseboard mounted locations as in apartment buildings . I replaced a few … Erie, Flair ??
I don't see the need for removing the valve body with Honeywells , the powerhead , motor and valve workings are replaceable …
Thank you for replying.
Is this the valve I would need?
Stocking a replacement powerhead would be a good idea, covers you for a bad end switch , gearing and motor …
- 116 Geothermal
